str8shooter_mn
Oct 01, 2016Explorer
str8shooter_mn wrote:
While driving, I sometimes get a warning beeping sound from the control panel for the hydraulic leveling system, which according to the manual indicates a low level of hydraulic fluid. When we retracted our jacks at the last campground on this trip, I noticed a small amount of hydraulic fluid on the wood pad for the right rear level jack. We have a 2011 Bounder Classic 36R. I have contacted Fleetwood and they sent me the schematics and drawings which indicated the reservoir if right behind the right front leveling jack and showed detailed drawing of pump and reservoir. However, to no avail, I cannot locate the reservoir or pump that matches the location that Fleetwood says it is at. Any help would be appreciated.
FOUND IT! Behind right front jack. Had to remove back panel of stairs. Riser of stair way is removable. Above coach battery box.
38,782 PostsLatest Activity: Sep 10, 2026
