goufgators wrote:
My MH has Kwikee hyd. leveling jacks. Recently, one of the rear jacks has begun to slowly extend while driving. When the 'jacks down' alarm sounds, I simply hit the up button, it retracts and then all is well for the next 50 or so miles at which time the when the alarm sounds again. I then again hit the 'up' button and we're good for another 50-75 miles. Before someone says the alarm is coming on because I'm low on fluid...that's not the case. The alarm comes on because a jack has slightly extended. Soooo, any thoughts about what the cause of this problem might be before I take it to repair shop? Any thoughts will be appreciated. / Larry
Solenoid valve leaking perhaps and if it has more than one, you may be able to switch them out and just to see if it might affect a different one.
