dsisemore1Explorer IIDec 21, 2020Hydraulic leak on room slideoutI have an HWH Spacemaker room slideout. I noticed hydraulic oil had dripped on a chair that I had placed in the bay. I could see there was a very tiny bit of oil at the bottom of the cylinder where ...Show More
Flute_ManExplorerDec 21, 2020If the oil is coming out from the rod seal you could remove the cylinder and have a hydraulic shop replace the seal.
Related ContentNautilus P1 has leaking connectionsHydraulic operated slideoutHydraulic Hose leak.Problem with slideoutHydraulic leak
