MountainAir05
Dec 21, 2020Explorer II
You can also flush out the old oil and replace with new synthetic oil and wipe down the cylinder with that and cycle it in/out several times with fresh oil every time. Then wipe it down clean and see if it lube the seal, if not then as stated time for a rebuild.
I worked hydraulic cylinders for over 23 years and that always was the first choice on a minor leak to try , then the rebuild if it got worst.
38,782 PostsLatest Activity: Sep 02, 2026
