big_boulder's avatar
big_boulder
hydraulic leveling jacks will not extend
I have a 2004 Four Seasons Hurricane class A with hydraulic leveling jacks. With engine on and e=brake engaged I an hear an electronic click when I toggle to every position on the floor plate. The floor plate on switch lights up OK and the 5 amp fuse in the floor plate is good. Hydraulic fluid level in the reservoir seems normal. Other than the faint clicking I hear when toggling to front, rear, right or left, I am not getting any lowering response. The control box underneath looked OK with no obvious damage or leaks. Any ideas? Is there a seperate hydraulic pump located somewhere?
  • FIRST thing is to state the BRAND of Jacks. IF you have HWH and you hear that click, go the Pump assbly and that click is probably the solenoid that is bad on the pump. If not HWH then state the brand. Doug
