zach477's avatar
zach477
I jinxed myself. Now I have a water heater problem.
Yet another problem has presented itself. I hope I run out of problems soon...
I have been hearing my water pump run randomly for about a half a second here and there. So I started searching for leaks.
There was a wet spot on the ground under my water heater. It's an atwood. I could see water slowly dripping out of the drain plug, so I tightened that thinking I fixed the problem. However the water pump is still doing its thing.
The wet spot has returned under the water heater, the water is dripping from somewhere inside the water heater. I had the water heater off for about 12 hours and it was still leaking.
It's has only dipped below freezing for a night or two around here. In afraid I may not have had the water heater on at that time. :/
I don't have time right now to investigate further. I'll have to wait until tomorrow. I'm. hoping it's not expensive to fix, but I'm fearing it might be. I'm feeling a little defeated at the moment. Also just found out my dog has to have an expensive surgery to removed a growth that could be cancer. Sorry. I'm just venting now....
