- Bird_FreakExplorer IIIf you have no luck on used check a company called Lokar in Tenn. They make custom shifters and pedal assembly's. I used their kits and cables on almost every custom car we built.
- OkieGeneExplorerBTW for any used parts needed, I'd contact COLAW Salvage in Carthage MO (Joplin area). They're a big'un and are always worth contacting first.
COLAW RV sales is next door it's a big'un too. - Johnny_on_WheelExplorerHi there! Thanks so much for your advice. Yes, I think that's the best option and I'll go ahead and do that.
- MountainAir05Explorer IITake it out and go to your local boat shop and they can make you one. Call some before you run to them. If not look on-line. Have replace many that was made to fit. You also have some good RV places around you and just a tad North of Houston.
Just called a friend at the auto parts store and they have kits, that you make by adding a end. You must have your old one in hand to get the right length. Do not lose your fitting since you most likely will re-use them. - vidotchisExplorerIf you are looking for a used shifter cable then you can find it on eBay.
38,781 PostsLatest Activity: Aug 12, 2026
