CapriRacer
Jul 04, 2018Explorer II
There's a part of this post that I find disturbing:
Rule of thumb: Operating tire pressures should not increase more than 10% - and anything over 15% requires immediate action.
If I am reading this right, the tires are 80 psi max - so 15 psi is about a 20% increase. Something is wrong and it needs to be addressed.
The obvious thing is the starting pressure. Are you measuring in the cold of the morning? Tire pressures increase about 3% for every 10°F increase in ambient temperature. So if you start when it is 60°F, and get another reading when it is 90°F, you should see a 9% increase just due to the increase in ambient temperature. You shouldn't count that - and I suspect this is a major source of the pressure increase.
So take some careful measurements, taking into account the ambient temperature vs increases due to operating temperature. If you are still seeing high pressure increases - SLOW DOWN!! That's the easiest way to reduce the increase. Then figure out what to do next.
goufgators wrote:
….. But, (we're in Fl and roads get hot this time of year) as miles increase, pressures increase up to and sometimes over 15 psi above starting pressure. …….
38,782 PostsLatest Activity: Sep 10, 2026
