Octaneforce's avatar
Octaneforce
I weighed my rig. Need help with math
So i got my 30ft class a weighed today. With me in it, it weighed 13,060lbs total, 8400lbs rear, and 4660lbs front.
Now i know i should have fully loaded it but i didnt have the time or energy. With the basic math i did, Id say in fluids, gear, and people, I’ll add about 1500lbs, mostly on the rear axle.
I did this because i want to order coil springs from supersteer to replace my crummy front airbags. The springs im torn between come 4400-4900lbs or 5000-5300lbs. Im leaning towards the 5000lbs springs. All i need is 2 additional passengers and I’ll be beyond 4900lbs
My other question is how to calculate my tire pressure. My tires say 3525lbs at 110psi single and 3305lbs double. I keep my tires at the recommended 110psi and my coach rides like a brick. Id like to run less psi but im not sure how to extrapolate the numbers to determine my minimum psi needed.
