RE-TE
May 30, 2013Explorer
Might not be abe to help much but what I had:
2001 Mountain Aire with a Dometic Refer with ice maker. The ice maker quit I took it to the shop. They had to replace the "feeder line" then the ice maker went, so I had to replace it. The heater coil quit only fix was a new icemakr, $350.00 later I have lots of ice. The tech said the waterline has check valves in some and they will go bad. Good Luck. To fix you will have to pull the refer out to get at the back.
38,780 PostsLatest Activity: Nov 22, 2015
