campingman55's avatar
campingman55
ice maker water line
i had to get a house fridge and i am getting a new ice maker the question is the blue water valve that came with the rv fridge will it work with the house fridge and if not will the water line hook up to the new blue water valve or do i have to get a new water line
  • From the grammar police: Run On sentences are very difficult to read. Thanks..:)
    I'm not exactly sure what you are asking. The water LINE will be the same whether it's an RV fridge or a residential. 1/4"OD. However, you mentioned a valve. Are you referring to the shut off valve or something different. Also, is this ice maker going to be an add-on to your residential fridge or a stand alone unit? I'm confused (easy to do)as to what you're trying to accomplish.....Dennis
  • Yes, the water line on bth the RV and res. fridg. is the same size both are 1/4" O.D. lines. you will be good to go.
  • I'm pretty sure the water line will fit the residential style fridge. I repaired my previous rigs water line with a feral and nut from a hardware store that was the same size water line and nut as a household fridge.
