mtrumpet's avatar
mtrumpet
U-Line under counter ice maker not working.
This thread is a couple of months overdue for me..
We have a U-LINE Model ULN-BCM95-03 under-counter cabinet mounted Ice maker in our MH that hasn't worked at all this season since we pulled it out of storage a couple of months ago. It worked fine before we put it away for the winter. (It is stored in a heated building and never sees less than an average of 72 degrees all winter, so freezing was not a contributing factor.)
Here's what happens...
We turn the unit on, and the fan comes on, but cooling/refrigeration unit (unsure of the proper term for it) never comes on. It just sits there with the fan running. We had left it run for quite sometime to see if it would eventually turn on, but nothing.
I checked for any loose wire connections, and everything seems fine.
Any suggestions as to what else I might check?
