Executive45
Jun 13, 2014Explorer III
The replacement Ice Maker unit is now $99.99 at Lowe's or Home Depot...both of them carry it. That said, do you have any water in the space under the fridge on the outside? If so, your water line has come loose from the water fill tube. I had mine come loose three times in as many years. It's only a pressed fitting into the fill tube so they work their way loose. Check for water around or below the valve. If that's the case, the fridge must be pulled forward to access the line. There is no easy fix......Dennis
