bsinmich
Mar 18, 2014Explorer
gswcgi wrote:
I had an Allegro, 1985, 23' with a 454. It suffered from massive vapor lock issues. Since I bought it new I called old man Tiffin and he finally relented and sent me an extra fuel pump to install in front of the fuel tank which solved the problem. The 454 was a real Turkey. Went thru 2 sets of manifolds until I changed to stainless Steel. It also burned up spark plug wires. Tiffin attributed all of these problems to the engine not getting sufficient airflow/intake.
Not getting enough airflow would be the responsibility of the coach builder. That has been a constant problem with some builders having heat problems and others having no problems with the same chassis.
38,766 PostsLatest Activity: Jan 10, 2026
