RayChez
Nov 20, 2015Explorer
A class A can be towed by a tow truck lifting the front end, disconnecting the drive shaft making sure the U-joint is marked with a chalk or yellow marker so that it will be installed in the same position it originally was. Disconnect the batteries, not sure why, but that is what the manual states.
As to what to do with the dolly? Hope you have a hitch behind your tow vehicle so you can tow it away.
Coach-Net also will load your coach on a flat bed. I have seen even commercial buses loaded on lowboy type flat trailers and carried away.
38,769 PostsLatest Activity: Mar 31, 2026
