Suspect list starts with the dead battery as someone said UP thread. See note below
Bad connection. On my Damon since they hooked 3 leads to the battery positive they used crimp on ring terminals instead of a proper battery terminal. the ring terminals are made of a different metal. Does not react much with copper but reacts like blazes to lead and acid.. Lead is less reactive to the acid so they had to be cleaned of rust and polished every couple years. Finally I visited a battery store and made an electrical "Edit" now the battery connection is a proper lead battery terminal and no more corrosion.
The battery ground.
THe famous "other" but odds on Other are ... low. very low..
The promised note:
My RV is a 2005. it has a B.i.R.D. (Bidirecitonal Isolater Relay Device) so if I'm plugged in .. as I am now. the Chassis battery is charged by the big PD-9180+wizard in the back of the rig.. (they put it a long. LONG way from the batteries) just as the house batteries are.. (and when going down the road the house is charged by the engine alternator.. ..Just like the chassis battery)
1999.. You might have had a one-way Isolator. Do not know
