csburks
Oct 01, 2013Explorer
ignition switch
I have a 2001 Georgie Boy Suite on a Workhorse chassis that I bought new. About 7 years age it would not crank right after I made a stop on the road. They had to replace the ignition switch that is ...
csburks wrote:
I have a 2001 Georgie Boy Suite on a Workhorse chassis that I bought new. About 7 years age it would not crank right after I made a stop on the road. They had to replace the ignition switch that is down inside the stirring column. At the end of last October the same thing happened and replaced it again. Last month I was having trouble cranking it and it was bad again. They have not determined what is causing it. Can you give me any help?
