csburks
Oct 01, 2013Explorer
ignition switch
I have a 2001 Georgie Boy Suite on a Workhorse chassis that I bought new. About 7 years age it would not crank right after I made a stop on the road. They had to replace the ignition switch that is ...
JimM68 wrote:
Things where you stick the ignition key in the side of the steering column do now ever have the actual switch there.
The key moves a rod up and down the column, and the actual switch is bolted to the side of the column under the dash somewhere.
/there are adjustments in the steering column that effect the movement of this rod.
It sounds like yours has never really moved far enough.
