I have a 2001 Georgie Boy Suite on a Workhorse chassis that I bought new. About 7 years age it would not crank right after I made a stop on the road. They had to replace the ignition switch that is ...
This is a common problem on the P32 Workhorse with some Motorhome builders. They overload the ignition switch. you can verify this by taking the switch apart and finding a burnt connection. Mine was bad enough that you could see the burned area without taking it apart. A relay will fix your problem.
