csburks's avatar
csburks
ignition switch
I have a 2001 Georgie Boy Suite on a Workhorse chassis that I bought new. About 7 years age it would not crank right after I made a stop on the road. They had to replace the ignition switch that is down inside the stirring column. At the end of last October the same thing happened and replaced it again. Last month I was having trouble cranking it and it was bad again. They have not determined what is causing it. Can you give me any help?
  • Check the cable in the steering column for fraying.Sometimes metal burrs or other forgien material will get into the column and cause the insulation to get rubbed off, causing a short.
  • Where are you taking it for repairs? I would take it to an authorized Workhorse service center. there are 27 in Texas.
