- wolfe10ExplorerPlease tell us what motorhome you have. That will make a significant difference is suggestions.
- wa8yxmExplorer IIII can disable the engine on my Workhorse by simply pulling a plug... Now the catch is I'm not going to tell you which plug. but if that plug is pulled it will crank all day (or till the battery dies) but no start.. And no damage.
- Dutch_12078Explorer III
azdryheat wrote:
Do motorhomes get stolen?
Yes...
Stolen Motorhome
Facebook: Stolen Motorhome Database
Stolen Motorhomes - azdryheatExplorerDo motorhomes get stolen?
- STBRetiredExplorerPrevious owner installed an alarm system on this MH that disables the ignition if triggered. Never use the thing but looks like major hassle to remove.
garym114 wrote:
If I thought I needed it I would put a switch on the fuel pump 12v power line.
I haven't felt the need to use it, but a previous owner installed a matching switch in a blank spot on the existing dash switch panel that's just labeled "Accessory". Turning it off disables the fuel pump relay. I did test it though, and it does disable the coach quite effectively as expected. - garym114Explorer IIIf I thought I needed it I would put a switch on the fuel pump 12v power line.
- way2rollTrailblazerI saw your other post about a GPS tracker - do you park your RV in downtown Philly? What sort of security outside of a locked door and removing the keys are you looking for?
- gboppExplorerHow about a simple battery disconnect switch on the chassis battery?
What exactly is your goal, for the rig to not start or, not to be able to move when it does start?
