doxiemom11
Dec 25, 2013Explorer II
You don't mention that you hear the burner light. Your fan should come on for a very short time, then the burner should ignite. Is you igniter misaligned. Or -- do you hear your burner attempt to light 3 times while the fan is blowing cold air? When ours did the try 3x and not light and was going into lockout, we had to replace the circuit board. If you could explain the above, maybe someone with more technical knowledge could walk you thru the problem.
38,764 PostsLatest Activity: Dec 25, 2025
