Old-Biscuit
Dec 25, 2013Explorer III
klm wrote:
Op. Burner did lught. Very low flame. Batteries 13.6. Can smell gas in rv. Have shut it down until further advice.
Then you have a propane flow problem.......
Reclose propane tank shutoff valve. Then slowly open again.
Also need to check that LP Detector is reset and that the propane tank solenoid is opening.
Then check that you have good flow/flame on stove top burners
If good turn t-stat off then back on and try furnace...may have to do couple times..Provided you get propane flowing. (Stuck/bad regulator???)
OH Say 'bycrackey'
Do you have any suggestions to help OP or just comments?
38,763 PostsLatest Activity: Dec 25, 2025
