klm
Dec 25, 2013Explorer
Op back again. I had a chance to replay in my mind the situation. I arrived in nj with a full onboard lp tank. I immediately switched over to aux tank. Yes did the soapy water no bubbles. Everything worked fine, furnace and stove. Then last night after disconnecting hose and aux tank trouble began. Back to the disconnect, all was normal, turned onboard valve to open did more soapy water stuff. I set the thermostat for 60 and went out for the night. Returned to find a cold rv. Tried some of your suggestions but no heat from the furnace and no stove burners. I survived by placing e heater in wet bay and another inside blowing into plumbing. 44 degrees. Brrr. OK this am in the light I notice the level of onboard lp had droppwd. How can this be? The know was "closed" and yes I am 100% sure. Anyway once I reach my fl destination I will have the mobile technology (have uses him before and he's good) check the entire lp system. I'll let you all know and thanks again.
38,764 PostsLatest Activity: Dec 25, 2025
