RLS7201 wrote:
If you have the older Ford 460 F53 chassis, Ford's owners manual allows 8K lbs. towing capacity. But then Fleetwood derated it with their frame extensions. Sooooooooo, the drive train is good to go. Those worried about the drivetrain are clueless.
Richard
Bingo
Fleetwood does down grade the towing capacity cause of the frame extension and the hitch they install.
My 08 Bounder is rated at 5000 lbs from Fleetwood but Ford rated the chassis at 5500 lbs towing.
The small F-53 chassis have a higher towing rate around 6000-7000 pounds by Ford but yet Fleetwood still pushes them out of the factory at 5000 lbs even today.
