Maxtorr's avatar
Maxtorr
Information Panel Above stove
Not knowing the proper name for it, there is a panel above the stove that has a row of buttons, pressing gives various information such as level of water in fresh water tank, grey water level, etc. My button for fresh water popped out.
Is there any reasonably simple way to fix it? The panel looks to be one unit with no simple acess to the buttons. The button looks like it may have broken on the sides allowing it to fall out.
I tried to set up a Goodle picture account to use here but it was above me how to let others see it without opening the whole computer to people.
Any help appreciated.
2001 Fleetwood Southwind 35R
  • Thanks for the replys. Sounds like a bit more than I want to tackle. I've never seen the panel off so I have no idea how many wires and other things hook in to it but in my case and with my limited knowledge I think I will leave it alone for now. That empty (broken) socket does just jump out and hit you in the face every time you look in that direction. though.
    Thanks again
  • @Maxtorr, re posting pictures, the piece of the puzzle you are missing, and why it appears you can't post pictures without "opening the whole computer to people" is that you cannot post a picture to the forum here without uploading that picture to a server somewhere on the net. People do not see the image ON YOUR computer, they see it on the server. So you make a one-time transfer/upload of the picture, and only the picture, and everybody sees what you uploaded, not where you uploaded it from.
  • Gjac's avatar
    Gjac
    Explorer III
    On mine it has 2 or 4 screws holding the flat panel to the stove top face. After removing these screws I was able to squeeze the sides of the plastic switch from behind the panel and replace it. They are momentary switches.
