- IvylogExplorer IIII found them on eBay under child safety locks... I liked this style the best of all the ones I saw The cheapest came from China so several weeks to be shipped. I'm sure you could find them from a US reseller for a little more and quicker shipping. I like to have spare items so I bought the five pack and painted three of them black.
- GGCIIIExplorerIvylog
I'm almost finished with my new fridge. Where did you get the latches on the doors? They should work well. Thanks for your help. - IvylogExplorer IIIThis refer is not a counter depth unit so it sticks out more than the NOCold... 6" plus the handles. It's the same amount as the hallway behind it so not a big deal, so to speak.
- IvylogExplorer IIII just finished a test run on battery power (500 AH) and at the start with 13.2V my inverter was drawing 7.5 Amps as the battery voltage dropped the amps increased to 8.3 at 12.4 V. At one point the amps jumped up to 22 and I'm wondering what's going wrong:h ... it was heating the ice tray to harvest the ice. :B
Even figuring a 75% duty cycle (18 hours run time) that's aprox 144 AH/day so almost two days before needing to recharge. I tried setting the inverter to power down when not needed, but it will not power back up so when waiting to go to work it draws 0.7 amp. I left the door open so I could see how many amps it took to start the compressor... 32 very briefly so a 500W PSW inverter would be big enough.
I already have to run the generator 1.5 hours in the evening and another hour in the morning and with the new 100 amp charger, that should not change.
For less than $10 this 12V/100amp meter is nice for monitoring my new battery system. - IvylogExplorer IIII was just at HDepot getting water line fittings and they have basically the same Whirlpool refer on sale for $648 plus $99 for a ice maker... I bought mine at a Sear's Outlet for $500 including ice maker, but that was six months ago as scratch and dent. In years of looking this is only refer over 16 cu ft I found that was not 70" tall.
WRT311FZDW... white
WRT311FZDB... black
SS for $949.
PS: OK Dennis, how did you rotate my pictures? - Executive45Explorer IIITwo quick things...first, before you hook up your water line, get one of the thin water filters. Mine had enough room in the back to put the filter there for the ice maker. Access was through the existing inspection panel for the Norcold. Second, I used gorilla tape to close off the panel on the inside so there's no draft from the outside. The residentials don't need that much air.
Oh! and you saved $400 by sliding that sucker through the window. No one believes they'll fit. That's what I paid for mine to be put in the living room. They pulled out the emergency window, slid the Norcold out onto the forks and reversed the procedure to put the Samsung in the living room. I installed it from there in the campground. Pretty easy and now we can have ice cream sandwiches that stay hard...:)...excellent job...Dennis - IvylogExplorer IIIOK Dennis, how did you rotate my pictures? Thanks!!! Like you I went the Amish route which helped the 1200 operation and I may miss checking the remote temperate reading several times a day. Anyone need a Amish cooling unit?
This EnergyStar Whirpool 21 CuFt Refer has a energy guide of $44/year and 410,000 kWh/year or 1,123 W/day or 94 Amps/day... So out of my 500 AH battery bank I should be able to go two days before getting to 50% and needing to recharge. $44/year is 12 cents a day... It's amazing how energy efficient they have gotten these things.
Bought these to hold the doors shut when traveling but may have to paint them black for the DW... guess she earned it helping to get it in.:B
Had some black plastic paint so I installed the door locks. Need one fitting to hookup the ice maker and that should complete this project.
*I would hate to pay someone $100/hour to do this project as the labor on my PSW power system would have been more than $1000 and removing the side window and modifying the cabinet plus installing would be more than $1000 also. OOPS, without a JD (John Deere) you will have an hour with three guys... $1300+
If you are not tall then installing a top freezer unit closer to the floor would be my recommendation.
Just thought I was finished with this project... have to put the side window back in.:S - BobGedExplorerExcellent job, and congrats to you and your DW for completing the project yourselves.
- Raist11ExplorerI have to say, the most impressive part of this for me is sliding the fridge through the window with the skid steer.. by yourself. And now I'm embarrassed about having trouble getting wrenches in to get at the top bolt for my front shocks. ;)
Ivylog wrote:
I bought a Whirlpool WRT771RWYB 21 cu ft refer as I hoped it was short enough to fit in the hole of my NoCold 1200. Cutting out the board at the top that holds the 1200 in still left me 1/2" short on the needed height of 65 1/2". The DW did not want to give up the large drawer under the 1200... So I cut out the 3/4" plywood floor and put in side rails for the edge of the refer to sit on. Sorry but I do not know how to rotae pictures on my Iphone.
Filled in the bottom with 2 pieces of 1/2" foil faced insulation that I had behind the 1200. Added four steel angle brackets at the front cross piece to help hold the weight of the refer that cantilevers 6" out from it. Not shown in this picture.
I've had my 1200 out so many times it's something I do by myself using a platform to slide it out on to and then I can slide it to the floor and then walk it out of the way or in this case, up front. Was able to get the 1200 out the side window without the four doors on and putting two boards over the coils/fins so I could slide it out on it's back. Used the 3/4' scrap plywood on top of the steering wheel to help slide it out. With some help from my John Deere skid steer I was able to get it out by myself.
Getting the new on in took some help from the DW to get it to slide in without hurting the driver's chair. Getting it into the hole took some effort as it's a tight fit, but we got it to go.
Without the passenger's side LR slide out the bottom door will not open all the way. The driver's side slide comes in the same amount as this new refer stick into the hallway so other than the door not opening all the way when traveling, I'm happy with how it's turned out and I did not have to modify the drawer under it.
Welcome to the "Formerly known as Norcold Owner's Club"...Dennis
38,763 PostsLatest Activity: Dec 13, 2025
