Old-Biscuit
Dec 07, 2017Explorer III
You will need to do some repiping......
Shutoff solenoid ---then the 'Tee Adapter'------then connected back up to inlet side of LP Regulator
LP Hose from 'Tee Adapter' to side of MH (same place as Shutoff Switch and Remote Fill would be spot) so you can connect another hose with quick connectors for hooking up a portable propane cylinder
When using portable cylinder you would 'close' tank vapor valve (Shutoff solenoid OFF) then valve in portable and it feds into your RV System thru LP Reg.
38,782 PostsLatest Activity: Sep 10, 2026
