dieseltruckdriv
Apr 01, 2016Explorer II
kwplot34 wrote:I have been using a Honeywell smart thermostat for several years now. I wired mine up only using the high AC fan speed like you did, and have never felt a need to hook up the switch for the low speed. But I wasn't sure at the time, so the option is there.
I am using the option for the 5 min delay on compressor start up, seems like a safe move. you can turn that feature off. I did not install a switch so I can have low or high fan speeds, wired it so its on high all the time with the green wire. The grey wire for low is taped up so if I decide to install the switch later its right behind the t-stat.
38,782 PostsLatest Activity: Sep 02, 2026
