tarnold
Jun 27, 2017Explorer
The trick to getting it right the first time is to determine the position of your steering wheel when going down a long straight road. Mine is off about 2 degrees to the left. This is the position you want your wheel to be in when you do your install. Just last week had to replace Miya Roadmaster where the return spring had pulled loose from the damper. Their tech support was GREAT as they sent me a new one to acampground we new we were to be at for a few days. Now about the "backward " install of the drag link bracket. I also called on my original install about was it ok to install backwards and they said ok. However when I replaced mine, I noticed the paint on the spring was scrapped off, in one area, like it was rubbing against the Backward placement off the U bolts. I installed the new one with the bracket U bolts installed to the driver side as it should be. I returned my damaged one back to Roadmaster with a note as described above. Just saying, check your bolt clearances.
38,782 PostsLatest Activity: Sep 10, 2026
