tarnold
Jun 28, 2017Explorer
There is a metal cupped washer that keeps the spring on. On mine the spring pulled over the cupped washer, either the spring end expanded or the washer wore somewhat and sorta shurnk. After talking to tech support, we came up with a way to reinstall the washer, but it pulled right out again, so they sent me a brand new shock. It looks like the new cupped washer might be a little bit bigger. We are still on the road and didn't have an accurat enough measuring tool to tell.
If you look at your drag link, it came move up and down quite a bit. Under certain road conditions, I believe the spring makes contact with the Ubolts if the bracket is mounted backwards. I would think cutting off the exposed thread after torqueing might prevent it from getting snagged. Again this time I mounted the bracket as it was designed.
38,782 PostsLatest Activity: Sep 10, 2026
