dougrainer
Oct 07, 2021Nomad
You can do the upgrade which has the adapter harness. OR, just go to the Intellitec Solenoid and jump the wiring between the 2 LARGE battery posts. That will bypass the disconnect solenoid. Use a heavy 6 gauge jumper wire with ring terminals. Have you tried E Bay for that panel? Doug
If you have the BD2 that means you have 2 solenoids. Chassis and Coach. If BOTH will not close and allow power, bypass both.
