dougrainer
Jan 24, 2021Nomad
tommy g wrote:
The Intellitec Electronic Climate Control System does indeed control all AC and 12v furnace functions. The unit controls all power shedding which is necessary for our 30 amp systems. I had to send mine to get it cleaned and refurbished(about $400.00). Check out this one https://waiterecc.com/. He's been developing it for quite sometime. If mine goes belly up again,I'm gonna look into this one.
This is a special Intellitec system developed for OLD Fleetwood and Winnebago using RVP(Coleman AC units). It has just 1 dual Wall Tstat and Control for the Shed and Tstat options. The only way that you can really fix is to install 2 new RVP wall AC control Tstats and probably bypass the Intellitec control for 30 amp shed control and monitor your AC amp usage on your own. You could install a separate 30 amp shed control like PCS. But, on a 25 year old Motorhome, it could run into thousands of dollars. Doug
https://precisioncircuitsinc.com/category/energy-management-120v/
