Yaj
Dec 30, 2013Explorer
The wood on the bottom step in our rental MH sagged around the bolts and big washers. I got some 1/4" X 2" flat stock, cut and then drilled some holes in it, and then with new bolts sandwiched the step through the front and rear step mounts. Also I bent the outside bars so I could attach it to some structure. That eliminated all the sag and any creaking noise. It really strengthened the whole step assembly.
Good Luck!
Good Luck!
38,769 PostsLatest Activity: Apr 03, 2026
