Gjac
Jun 29, 2015Explorer III
Ava wrote:Doug what chassis did you have. When I looked at my P30 chassis the sway bar is attached to the AArm and frame the upper supports are riveted on. Are you saying the upper bracket was loose and banging into the frame?
Hi, my 94 Bounder had a banging up front which I finally fixed. The big sway bar is attached to a hanging bracket on each side that swings slightly as the suspension moves up and down. The bracket was hitting the frame. There were some factory holes to mount the brackets one hole lower to clear the frame and barely changed the angle of the sway bar which solved my issue. Probably not your issue but maybe helpful for someone else. Cheers Doug
38,763 PostsLatest Activity: Dec 05, 2025
