Jim_Bakker's avatar
Jim_Bakker
intermittent loss of DC coach electricity
I have an occasional and intermittent problem with loss of DC coach power. Here's the scenario: I drive into a rest area for a "comfort" stop, turn the engine off, switch the water pump on, it doesn't come on, further investigation reveals no DC power in the coach. I don't lose DC power every time the engine is turned off, but when I do starting the engine or plugging into shore power restores DC power. What might cause this, and what is the fix?
Coach is a 2004 Fleetwood Pace Arrow, on a Workhorse chassis.
  • dougrainer wrote:
    Your batteries are probably bad or the connections to the batteries are corroded and loose. Shore Power/Genset and starting the chassis engine just uses the Alternator(chassis) or the Power Converter(Inverter/charger) on Shore or Genset. Doug
    Batteries are fairly new, but I'll "break and make" the post connections.
  • BillofPA wrote:
    I had that problem and it was a bad relay that the "salesman" switch was connected to.
    I suspect this as well.
  • darsben1 wrote:
    I had that same problem. It turned out to be a defective disconnect someone installed on the - side of the house battery service. Intermittent problem.
    MIne looked like this
    I don't have one of those.
  • I had that problem and it was a bad relay that the "salesman" switch was connected to.
  • Your batteries are probably bad or the connections to the batteries are corroded and loose. Shore Power/Genset and starting the chassis engine just uses the Alternator(chassis) or the Power Converter(Inverter/charger) on Shore or Genset. Doug
  • I had that same problem. It turned out to be a defective disconnect someone installed on the - side of the house battery service. Intermittent problem.
