rhianna wrote:
We also have 4-100W solar panels on our roof which came with a 2000W PSW inverter which we were planning on using for the new fridge to protect the electronics in the new fridg, and 4 more 100W panels we recieved yesterday and plan on installing soon...The PSW inverter-converter/chargers do not have breakers built in so we will have to install seperate breakers and when we install the new panels we will need a bigger controler.
I'm not sure why you need another inverter if you already have that first 2kw you mentioned. I guess that's not a charger?
And if you wire an inverter to your electrical panel you don't need any additional breakers. You use the breakers that are already in your coach's panel.
It's Aims, not Aimes, and they are not the best quality.
