Swampman597's avatar
Swampman597
Disabling the converter charger when using the inverter
Apologies if this has been answered but a search didn't help.
If I install a disconnect switch in the positive lead from the converter to the batteries, will this create a problem?
This would be only for the times when the shore power cable is connected to the 2kw inverter to avoid having the batteries trying to also be charged by the converter. Its a 55 amp WFCO converter that I upgraded to the WFCO 9800 series converter with a 3 stage charger. The inverter also has a 3 stage charger which I use to charge the batteries with the generator when dry camping so I wouldn't be losing the ability to charge the batteries. At full hook-up sites, I'd close the switch to allow the converter to charge the batteries and the inverter would just be idle.
It seems like it would work but just wanted to check in advance.
Thanks,
Mike
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
