rsaf1947
Oct 17, 2013Explorer
Inverter Issue
Our inverter is not working right and I'm not expert on them. The system shows and charges ok that the battery is almost full. When we put anything on such as coffee maker, tv or whatever, it goes i...
rsaf1947 wrote:Ivylog wrote:
Three years hooked to power and I'll bet you have not put any water in the house battery... YOU need a new deep cycle battery with caps where you can put water in every two months.
I check the batteries routinely and have added water whenever needed. There hasn't been a time when the water level was too low. The cables have been lubricated with truck lube and there is NO corrosion on them whatsoever. Corrosion and low water are not issues here.
