rgatijnet1
Apr 10, 2015Explorer III
Here is the link to your coach specs: 2005 HR Admiral
Your unit comes with a 55 watt 12 volt converter as standard with an inverter as an option. Since it is an option, there is a good chance that a lot of the wiring is already in place and the installation may be fairly easy. By the same token, your 55 watt converter should be sufficient to power your TV without the generator.
The other option, and maybe the least expensive, is to change your TV to a 12 volt flat screen which would allow you to run it from your existing battery bank.
38,771 PostsLatest Activity: Apr 14, 2026
