jdb7566 wrote:
This morning we had a small electric heater turned on to remove the morning chill and was plugged into one of the outlets controlled by the inverter. We are plugged into shore power, so without much of a thought, went to use the microwave, also on the inverter circuit, all outlets went dead. There is a gfi outlet near the bath sink, it did not trip, and will not reset. Checked for a tripped circuit breaker, none found, no blown fuses in the fuse box. The inverter continues to charge the battery banks, current is good through the inverter class t fuse. There is a gfi outlet in the engine compartment, it works fine. This is a 1999 Monaco Diplomat DP. Every thing I've checked, checks out fine. I replaced the bathroom gfi outlet, still nothing. I'm at witts end trying to figure this out. All suggestions are welcome. Thanks in advance.
Thanks for the suggestions, I'm blind in one eye and can't see out of the other. I never saw, though I looked right at them, 2-20A push type reset breakers. Everything works again, like it should.
