alexcc1
Aug 31, 2016Explorer
inverter problem (will not turn off)
Bottom line: My heart 20D inverter will not turn off.
I have a 1998 Safari Sahara with a heart 20D inverter. I got it out of parking and brought it to the house. When I parked it the inverter was on even though the control panel switch is turned off. I checked the switch on the front of the inverter and it is also off, yet the inverter is on.
Contitions:
Shore power: disconnected
Generator : off
control panel switch: off position
inverter on/off switch: off position
yet the inverter is still on!?
Background:
about a week ago I checked on my RV and found the house batteries dead. I refilled the batteries with distilled water and started the generator with the chasis batteries using the interconnect switch. While charging the batteries the inverter tripped off and displayed an overload LED. I latched the inverter compartment door open for better cooling, shut down the generator and let it sit for 20 minutes before restarting and charging. After the batteries were only pulling 20 amps I shut down the generator and called it a day since I was going to bring it to the house to get it ready for a trip. I did not notice any lights on the inverter control panel at the time.
Fast forward 1 week and now the inverter will not shut down. I checked both switches: stays on. Disconnected the control panel: stays on. Checked all of the breakers and fuses and they are good. I don't know what else to do other than disconnect the battery cable to shut it down. And that is just to keep the batteries from getting drained again.
I am looking for ideas and input.
I am also looking for a schematic for the inverter since I assume that there is a relay stuck closed causing the inverter to remain on.
Alex
UPDATE 2 Sept 16
When I said the inverter comes on, I mean it produces 120V AC power; the lights on the microwave comes on.
I disconnected all batteries and the solar panel and let the rig sit overnight. When I reconnected the batteries (all switches still off)the inverter came on producing 120V AC.
I removed the inverter control panel in the RV and unplugged the communication cable / network cable /telephone looking cable, and the inverter shut down.
To isolate the power switch on the inverter control panel I desoldered one of the wires to the on/off switch. I then plugged the communication cable in and the inverter began producing 120v AC; unplugged the com cable and the inverter shut off. So I resoldered the wire to the on/off switch.
Next, with the com cable unplugged and the inverter off, I went to the inverter and turned on the inverter on/off switch. the inverter came on, producing 120v AC. Turned off the inverter on/off switch andd the inverter shut off.
I took the cover off of the inverter control panel, there were no obvious signs of damaged components.
My next move is to buy a replacement inverter control panel, and check the system operation.
Any other suggestions?
Contitions:
Generator : off
Background:
Alex
UPDATE 2 Sept 16
