CINPHIL's avatar
CINPHIL
Inverter Question
Hi y'all. I noticed that my inverter, even with the coach and chassis battery switches off, stays powered. I can tell because of the hum that the inverter makes and when I go into the coach and turn the inverter off, the hum stops. I have a 2008 Monaco 40PDQ. Is this normal? Perhaps it is wired that way so I can hook to shore power with the chassis and coach disconnect switches off and still charge the batteries via the inverter. Thoughts?
  • Thanks, but that would be a battery drain when one thought by turning off the chassis and house switches everything was off. I appreciate the response! Take care.
  • Probably the way it is wired. I certainly would not lose any sleep over it. I never tested mine that way.
