KeninAZ's avatar
KeninAZ
Inverter Questions
We picked up a 2000 Bounder 31M in pretty nice condition.
I understand that it has an inverter somewhere that converts DC to AC on I assume at least one outlet and is limited in amperage.
I don't see the inverter nor do I know what outlet would be involved in it's use.
Anyone give me any ideas?
  • My bounder inverter is in an outside compartment just right of the entrance door. Typically the wiring needs to be as short as possible, so it should be close to your batteries.
  • We had a Bounder, and the inverter was behind one of the drawers in the bedroom. Good luck!
  • I will have to check this out when I go to storage next time. TNX
  • Usually it is associated with the entertainment center. If it has an inverter, the TV receptacle should be on it. There should be an ON/OFF switch near the TV. It may or may not have an internal transfer switch. Try the TV when not on Shore Power.
