wallynm
Oct 01, 2014Explorer
FTL some times uses Neway and I do not know about Holland. I agree and stated that CC made there own raised rail chassis.
dons2346 wrote:wallynm wrote:
CC purchased parts from every where and assembled them to or on there own designed raised rail chassis. If they purchased front end components from FTL then I would assume they would use FTL specs in the assembly.
gman421 wrote:
I just got the shop report from the RV Dealer that had the alignment done on my coach 4 days before I took delivery. I have a 2006 Country Coach with a DynoMax Chassis, the shop report used the spec's for a Freightliner Custom Chassis Corp: 1995: XB/XC/Powerline Chassis with/ Independent Front Suspension.
Is this correct?
Is DynoMax made by Freightliner?
The front end is not a Freightliner part. It could be either a Holland or Neway.
The DynoMax chassis was made in house at the Country Coach factory
38,783 PostsLatest Activity: Sep 24, 2026
