- Ken_CExplorer
map40 wrote:
The Dynomax chassis is no longer in production, right? Can you get parts? Is it better to avoid it? Any advice will be apreciated!
Except for the frame and it's design, all attached components are readily available items. We had a 2003 model until 2018 and the only chassis item replaced other than normal service was an seal on the Rt front wheel. Great driving coach - navigator2346ExplorerIn almost 190,000 miles, the only things that have been replaced on the chassis is a front wheel bearing and that is an off the shelf part and a ride height valve which is also an off the shelf part.
I would not shy away from the DynoMax chassis. The only coaches on the chassis is Country Coach and a few National RV's - map40ExplorerSo, not as easy as having a freightliner chassis, but you can find them. Is it worth it? Is it better than a freightliner of the same age?
- wolfe10ExplorerThe "frame part" is no longer available, but most can be easily repaired.
The components (axles, transmission, engine, etc) are common parts are are shared by many other motorhomes and OTR trucks. - map40Explorer
navigator2346 wrote:
The DynoMax chassis was built by Country Coach and yes, they are no longer produced. There are no parts on that can't be found
So you can or can't find the parts?? - navigator2346ExplorerThe DynoMax chassis was built by Country Coach and yes, they are no longer produced. There are no parts on that can't be found
38,783 PostsLatest Activity: Sep 23, 2026
