BruceMc
Nov 18, 2020Explorer III
Depending on the coach manufacturer, the house batteries may be behind an access door along either side of the coach, or in the step well just inside. Our Sunseeker has two group 27 12V batteries in the step well.
The extra battery is a GM option, and as Newbiecampers stated:
"Without the engine running, when you turn the ignition key to the very first accessory position, this frame-mounted battery will be powering the accessories instead of the battery in the engine compartment used for starting. "
Thus, this battery may or may not be in motorhomes based on the 4500 GM chassis.
It is this conversation that I've learned of the possible existence of an auxiliary battery on the GM 4500 chassis.
