Daveinet
Nov 21, 2013Explorer
Wait till you have some wind. Run the furnace. Go around with a can of great stuff and start sealing up anywhere you have cold air blowing in. I would expect you to use up 2 cans.
As far as heat from the engine, as long as your gauges say it is up to temperature, you should have pretty hot air coming out of the heater. May not be enough to heat the coach, but it should keep the front warm. I guess that is one advantage to a gasser is the engines run warmer and can put out more heat. We camp in single digits, but the engine heat will take care of the whole coach when driving.
