holstein13
Jun 11, 2015Explorer
I found some interesting information on the charging system. My coach is equipped with a Battery Isolation Manager. The Battery Isolation Manager (BIM) monitors the Battery Voltage of both the Chassis and Coach Batteries over long periods of time. If it senses a charging voltage, it connects the two batteries together. If the charging system is drastically overburdened, the batteries will be isolated, however, if the BIM sees a long term charging of both batteries it will allow the batteries to remain connected and allow the charging system to do its job. Once the batteries have reached a Float Charge state for one hour, the BIM will isolate the batteries to prevent overcharging, and will only reconnect the batteries for charging if one of the Battery drops to approximately 80% charge, and the other is being charged. If the batteries are not being charged, BIM isolates the two batteries to prevent an electrical draw in one system from depleting the other battery. The long term monitoring of the batteries prevents the annoying Relay clicking that exists in simpler Isolation Modules today.
This system works with both the coach's charger and with the alternator while driving. It is bi-directional.
Click here for more information.
38,763 PostsLatest Activity: Dec 05, 2025
