TANDDANDBIGE's avatar
TANDDANDBIGE
ISC 330 starter keeps runing
Have not started coach in 5 months and now the starter keeps running when the key is turned off. The only way I stopped it was to turn off the batt. disconnect in the batt. bay. I then toggled it on and off several times until I heard a "click" and the starter stopped. Is it possible that rust on the flywheel has the Bendix stuck engaged thus keeping the solenoid energized? Or what else? Any help would be appreciated. Thanks in advance TB
  • MountainAir05 wrote:
    How about the starter relay.
    I will have to figure out where that is......... not in the batt. bay. THX TB
    Probably not.
    More likely it is the starter solenoid itself sticking.
    Or a starter relay that drives it.....Or maybe even the ignition switch itself.
    A meter to test would be a REALLY good idea.
